i got a 2nd hand Apexi AVC-R [electronic boost controller] ... it is the current model, with the blue monitor.
Asking for $900 ... URGENT SALE
S-AFC is also for sale ... current model, blue screen too.
asking for $450 ...
only Perth buyers please :)
email [email protected]
https://www.sau.com.au/forums/topic/4432-for-sale-apexi-avc-r/
Also have a few 2nd hand parts off a MY99 WRX ...
- Computer replacement [Autronics] - $2000
- lightweight flywheel - $200, labour not inc.
- exceedy 4 puck clutch [used for about 1 month] - $300, labour not inc.
- apexi bow off valve [universal] - $400
- HKS front mount intercooler [brand new!] - $2500
- HKS exhaust [turbo back] N1 style - $1000
- genuine carbon fibre connet [brand new!] - $1200
- STi rear tail lights - $400
- STi rear wing - swap with standard wing, but you pay for painting [it is painted dark blue now]
selling due to getting rid of car ...
URGENT SALE!
rev210:
i do not think the flywheel will fit on an r33 ... i think they are car specific.
adam 32:
i will get back to you asap ... just going under offers at the moment.
G0DF4Th3R:
im not too sure` but i think you can buy an adaptor for it maybe around $80 ... unless you got a FMIC or somthing, then you can get it welded to the piping`
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
