Hey all,
desperately seeking help with a HICAS fault on my BNR34 V-Spec
During the install of a new fuel pump, the car was moved without the ATTESA or HICAS computers plugged in.
Since then it's had the HICAS light on the dash permanently.
I've taken it to two places for diagnostics (including Nissan themselves) and they've both given the same error code, as attached;
HICAS Error code 33: Engine speed signal
Sadly, here in NZ pretty much everyone i've spoken to has said "We don't have a clue"
This includes Nissan themselves (though they're happy for me to leave the car and a signed blank cheque with them :/ )
and several performance shops.
The obvious choice is to lock out HICAS BUT that's not really what i'm wanting to do as the system still works when in diagnostic mode.
I've been in for a wheel alignment since but it's still not cleared :/
Any help would be greatly appreciated!
https://www.sau.com.au/forums/topic/443371-hicas-fault-help-needed-please/
I can't help but I can tell you to not go to Nissan.
They want to sell and change oil on new cars.
Not mess around with old cars.
I would check all the plugs are clean and plugged in correctly.
Thanks mate - definitely steering well clear as they've said that whilst they have absolutely no idea about the problem,
they're happy to charge me about $200 an hour to look into it, with no kind of guarantee that they'll be able to fix it.
I work in IT - if we treated our customers like that we'd be out of business in a week.
Plugs have all been checked for bent pins and loose connections and I've been emailing various people about it but no one seems able to help.
Edited by Ares180BPM
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
