All ears tuned to Qld police scanners
THE days of the crime reporter hunched over a police scanner will be gone for good in Queensland if police succeed in a bid to keep digital communications secret.
Instead, the media could find itself restricted to a 24-hour police media unit, SMS messaging services and a broadcast dissemination service to newsrooms
https://www.sau.com.au/forums/topic/44351-no-more-police-scanning/
Bah...  What a waste of 90 dollas...  Oh well was good listening for a bit...  Although... It could be years before they actually do something...
It took them the whole 2 years and 9 months (plus the rest) that I was there to implement just the brisbane metro area.
But now that the network has been set up and proven to work, it probably won't take that long to get the rest of the state onto digital.
Anything the police can do we can do better :cheers: hehe
Someone will crack/hack or release something that listens to the digital etc
Its just a matter of time, but who cares anyway, if i wanted to hear of constable xxx pulling over a 14 year old for a bong in his bag a 2am then ide watch cops.
hehe
Hahahahahaha............ you guys are funny:)
DIgital scanners have been available all over the world, probably arrived last to Australia:)
and can be Hacked and Cracked to any country scanning system with a tiny little mod chip:)
Oh, and they work very well :thumbsup:
as the man was saying.. i think aaron was the one who told me you could crack them fairly easly actually :thumbsup:
the best part is cops will *think* nobody can listen in on anymore :) which is more dangerous than them knowing people can listen in...
Oh, and they work very well :D
Are these similar to the ones you bought for Genesis and Charly that didn't work :(
i can understand why the cops don't want us listen in, however i think it should be another one of those laws, like why cops without cameria/radar carn't book you for speeding without photographic evidence.
personaly i think that if cops can hide there vehicles and just leave the radar gun/speed cameria sitting out near the road ( and as for the radar signs that they have to have, how many of them have you seen facing the correct way on the road??) Then the public should be alowed to have radar detectors and police scanners.
just my 2 cents worth.
Makes sense, well we were able to avoid an pretty serious accident scene once due to listening to the scanner. Meant less cars at the accident scene and one less car for police to divert .... some times listening into them can be a good thing ....
  • 3 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
