After i sprayed some seafoam into the plenum through a vacuum line, the car started missing badly on idle and making popping noises from the exhaust. I turned up the idle to 1k now so it does it less frequently. What can it be? its a rb25 neo. While driving the car is perfectly fine though.
Edited by IM-32-FK
https://www.sau.com.au/forums/topic/443603-missing-on-idle/
Well that makes spraying "seafoam" a pretty useless use of time and money....
Maybe it dislodged some carbon and is caught in a valve?
I personally would never use the shit.
Rev car heaps and see if that fixes it
Or spray some other magic cure in there.
https://www.sau.com.au/forums/topic/443603-missing-on-idle/#findComment-7293431
how is it any different to any foam based carby cleaner? What other magic cures can i try? i used fuel injector cleaner a few month ago
Edited by IM-32-FK
https://www.sau.com.au/forums/topic/443603-missing-on-idle/#findComment-7293439
Why did you use the cleaner in the first place? What problem did you try to fix?
They aren't really a substitute for actually fixing the problem.
I would pull the plugs and see what they are like,they might be covered in shit.
https://www.sau.com.au/forums/topic/443603-missing-on-idle/#findComment-7293450
i did it just to clean up the plenum a bit since i never cleaned it before. Checking the plugs is gonna be a pain because i need to take the throttle body off . The car even misses on low revs below 3000 i realised.
https://www.sau.com.au/forums/topic/443603-missing-on-idle/#findComment-7293757
fixed the problem. The place where the spark plugs sit was flooded with coolant, especially the first cylinder. The plugs were also dirty so i cleaned them with a wire brush and contact cleaner. Car is running perfect now. Thanks for the help guys
https://www.sau.com.au/forums/topic/443603-missing-on-idle/#findComment-7298881
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
