I recently discovered something interesting regarding aftermarket BOV's and mentioned it in another post, however I thought more of you guys would read this fresh post and possibly benefit from the finding; that is if you don't already know about it.
It is regarding the turbo flutter which seems to happen a lot in many driving styles and situations. Being an auto they do tend to flutter a bit as we don't always come off throttle completely (not in the way you would in a manual anyway). The flutter sound is created by the turbos impeller 'chopping' up back pressure that is not released by the bov. This is not good for any turbo as it creates opposing forces on the impeller and bearings and would most likely reduce the life of a turbo.
The standard pressure hose going to the bov has a restrictor in it. It is about a third in from the end of the hose. The restrictor reduces about 4mm diameter down to about 1mm and would reduce the pressure sent to the bov to actuate it and therefore, having an aftermarket bov which usually have stiffer spring rates and are harder to open will not open or not open enough except when controlling the accelerator with a bit of gusto.
I replaced the hose with fuel line hose and noticed the difference immediately. I'm not sure how much you guys would notice due to us all having different setups, but I thought it would be worth a shot if it means prolonging the life of your turbo and having a more enjoyable ride.
I did this today, I still have a bit of pigeon noise, but from my short brap around the block it seemed less. It does seem to have smoothed out the stutter it had getting off throttle but until i drive along a 100km/h bit of road i wont know for sure.
I checked mine by squeezing all along the hose with pliers and couldn't find a restrictor, hose definitely looks factory. It's an Axis so maybe it's not on every model? Mine hardly stutters since I stiffened up the spring rate, it was heaps softer than the stock one before so I set it as close to the same as I could gauge and it made a big improvement with stuttering.
Just in case anyone else is looking for other ways to possibly improve the feel.
  • Like 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
