I know this has been covered a million times before but I cant seem to find info on removing the Hicas pump.
I recently installed a driftworks Hicas elimination kit.
I went for this kit as it completely replaces the Hicas setup and you can get rid of all the weight and crap that comes with it.
We removed the whole hicas setup and all the lines but we also removed some sort of pump and had to block of lines off up front.
Is this just the Hicas pump?
Power steer is all still working fine and there is nothing new weird things about the car.
I am wondering if I have done this right and if the fluid is now not getting access to the cooler at the front?
Should these lines be looped into each other?
When I remove the intercooler and replace it I am going to remove these lines and see where they go to. I obviously still want it to reach the cooler.
Anyone able to give me some info on this? Can I expect problems in the future?
https://www.sau.com.au/forums/topic/443973-removal-of-hicas-and-hicas-pump/
What car, I'm gonna guess GTS-t, in the GTR that thing you removed on the intake side is a divertor block that changes from the HICAS to the cooler, if you loop those two pipes it should just run through the cooler, that said that might be different to the GTR
