white skyline in midland
the same one but i was doin a u turn and got smashed into (big difference)thats y i can still get insurance for my line and it wasnt a right off it was sold about 2 weeks ago (trusty swift). and miles u can call me daddy if u stop bein a ***** and get a power fc u ***n girl oi check out the for sale section here there are second hand pfc's reasonably cheap or if ur to cheap cough(36000)cough then atleast get a ***n e manage. oi and how much did u pay for the avcr u keep forgettin to tell me.OI nugget hows debbie hahahaha still workin at that hole hahahahahaha oi me and u can race so get ur trolley ready hahahahaha.
ps wassabi kiss my :shake: hehehehe:D
Originally posted by G0DF4Th3R
coz i got my skyline 4 days ago and when i see other Skylines on the road i keep wondering if the owner is part of skylinesaustralia forums. next time u guys see a black skyline with a bald guy in it....wave!:D
I see ugly people with skylines almost every day!
cheers
Joe
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
