Hks rear Coilovers suit r33 s14 s15 $200
Mahle forged pistons rb26 86.5mm $250
apexi power fc rb25 r33 with commander $800
apexi power fc rb25 neo r34 gtt $800
microtech ltx8 ecu no loom $400
Sard 700cc injectors direct plug in for rb26 $300
splitfire coil packs suit rb25 neo $350 2 months old
z32 air flow meter $140
greddy eo1 boost controller comes with remote etc $300
apexi rev speed meter blue screen $150
intercooler bar and plate 600x300x76 $90
Exedy oem clutch suit rb20 rb25 rb26 push type only 1 month old $150
Exedy lightened flywheel suit rb20 rb25 rb26 $100
Speco water temp gauge and sender $30
Greddy plastic washer bottle for r33 $30
Tow hook $10
Catch can $10
3 Gauge pod $10
Clarion 4 channel amp $40
Pioneer 12inch sub in box $80
gold coast
0487924497
Edited by toy515
Pics when you can of:
Catch can $10
3 Gauge pod $10
Interested in all 4, once I see pics we can PM re: price...
  • 3 weeks later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
