Parts located in Wollongong. Contact by SMS to 0415 954 550. Don't call, can't answer at work. Pics available on request.
S14 non-hicas subframe $50
S14/R33 rear LCA $50 each
R33 front LCA $120 for the pair
S14 front end - both LCA, knuckles, 5 stud hubs $250
R32 GTR front brakes $300
twin caliper rear setup: S14 non-hicas knuckle, 5 stud hub, caliper adapter, spacer for the rotors, skyline rotors, and two pairs of skyline twin pots. Will connect to standard rear brakes, needs a hydro and line made up. $350 for the setup.
White line S14 front swaybar $150 (the older blue ones, three point adjustible)
Whiteline S14/R33 rear swaybar, $150
R33/S14/S15 Adjustible toe, camber and traction rods. Generic e-bay guys, used but good condition. No play in ends. $80 each pair or $200 for the lot.
also a bunch of S14 stuff
Tein HE drift spec/winding road coilovers. No leaks, good condition. $700
genuine URAS kit, been run over a few times - front/rear bars, sideskirts. $100
widebody vented guards, unsure of brand or mm width, near new condition, still in primer $150
vented FRP bonnet, has holes from bonnet pins, needs paint $200
genuine ganador mirrors, non-indicator, clear lense, carbon type. Carbon overlay on drivers mirror is worn. $200
https://www.sau.com.au/forums/topic/444486-r33-and-s14-parts-r32-gtr-brakes/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
