I have no idea!
probs should find out.
if i could read the export paper i probably would know hahaha
I'm changing the wheels
as for engine mods im not to sure at the moment. anything you would recommend me doing first?
https://www.sau.com.au/forums/topic/444576-heyyyyyy/#findComment-7314730
Post the export paper up here if you would like me to have a look at it.
There are a bunch of different paths you can take when modding the RB25. The main factors affecting your choice are. What you are using the car for. What your goals are. How much you want to spend. The best thing to do is browse these forums as there is a massive amount of info on here. Personally I would be looking at a GT35R based turbo with the supporting mods for around 300RWKW while still being daily driveable and affordable. If you have a bit more cash to throw around then a Precision or similar turbo. If the sky is the limit then get an LSX engine and twin turbo it. You will want to consider running E85 if you are going to go to a bigger turbo, not because it is necessary but it does give a good increase in performance while still being kind to your engine. These might sound like overwhelming decisions to make at first but if you decide up front it means you will know where to start with your supporting mods. For example there is no point getting slightly bigger injectors if you plan on running E85 and 20psi of boost in the future.
Edited by *LOACH*
https://www.sau.com.au/forums/topic/444576-heyyyyyy/#findComment-7315566
  • 4 weeks later...
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
