  • Replies 126
Hey we've got a cruise coming from Sydney to the Central Coast on the 19th too, we're heading up for a lunch at Terry Ashwood's restaurant in Sydney.
Details for club members are here:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=56886
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1112932
ok cool.. duncan im currently looking into membership now only found the link today thanks to lwells.. anyway 19th is great.. if you could give us a time and place to catch up with you all from sydney that would be great.. newcastle people.. what should we get upto on the day, meeting spots and times, things to do etc..
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1113078
Do any Newcastle Nissan dealerships retail Nismo parts?
Yes, I could ring around, but thought I'd ask just in case someone here had a friend/mate/contact/whatever at Nissan rather than the standard parts department blank look that says "You've got to be kidding, right?"
Any info/tips appreciated.
Mark
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1116694
What do you need?? Depends what you are looking for from the Nissan catalogue. Kloster parts stock/have bits and pieces available ex-Japan for import Nissan's but the main place to get Nismo parts would be Unique Autosports in Sydney. www.nismo.com.au
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1116858
Hey the 19th sounds pretty good, La Porchetta aye.....show of hands? we can either meet up at the twin shells at wallsend or at spears point park. Would also be good to meet up with the sydney guys at their exit, then we can cruise in as one group, sound good?
Hey chris there is a charity cruise on this sunday, so you maybe could make that one :P
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1116941
Thanks for the info guys. I was looking at Nismo S-tune suspension kits. I've looked at the UAS site and I'll get in touch with John. I hadn't considered Powerplay, thanks for the tip.
I'll see how I go with Kloster.
boj01: When you do your P's, practice lots and hire a CB250! If you want to know the distances for the P's test, either get a few hrs private tuition at Adamstown or send a PM. Btw When I did my P's at the start of last year, it was pouring rain, and 2/6 people on the course crashed out during the brake test!....It was rough watching that happen, and then they called my name next!
Mark
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1118671
Hey. I used to live in Newy. On the Gold Coast at the moment but will be moving back early February so i'll be cruising into the foreshore to have a look around. I'll be up for any cruises after then, it would be good to meet up with some new people.
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1119877
hay all, i was going to go on the charity cruise but was to buggered as i just drove back from QLD. i will be on the central coast cruise. would it be alright if i brought a mate with a 180? garenteed it will beat most everyone here so it is worthy.
https://www.sau.com.au/forums/topic/44473-newcasle/page/4/#findComment-1121786
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
