Hi guys have a few things lying around I need gone
Location hills area sydney
Prefer cash only pick up
Due to my computer being all screwed up I can send pics via SMS only at this stage
0419575458
All parts where off my r34 gtt and are negotiable
S tune suspension genuine nismo product damper only adjustable
$500
Standard injectors all 6
$50
Standard coils all 6
$50
Standard side mount intercooler
$150
Standard air box with snorkel
$100
Standard gtt 17" wheels w/tyres
$300
Standards exhaust manifold
$80
Standards top half of intake tb included
$100
3" jjr dump pipe bell mouth
$100
Split screamer dump pipe
$50
Passenger side genuine xenon headlight
$300
More to come once engine build done
Cheers
Jason
  • Like 1
https://www.sau.com.au/forums/topic/445089-gtt-garage-clean-out/
Update:
Found more parts
Triple cluster $40
Stock afm $50
Stock fuel pump $20
Stock disc brakes all 4 $50
Stock side lamp indicators $30
Stock front lamp indicators $30
Stock steering wheels with air bag $200
Cheers
Jason
I'll take the coils assuming they are in good condition (were running fine before removal) and that you are happy to post to Melbourne.
At this stage due to work commitments very long hours I am unable to post at this stage
Sorry
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
