SWAT = Stagea Web for Advanced Tuning in case you guys din know, they've got branches all over japan.
here's the Hokkaido one...
http://homepage2.nifty.com/WGNC34/
the michinoku one
http://www.swat-michinoku.azn.nu/
tokyo...
http://www1.odn.ne.jp/~cch71670/
Kyushu
http://www.miyazaki-catv.ne.jp/~h-mawa/index.html
And here's a page of japanese stagea related links...
http://nissan.fc2web.com/stagea.htm
babelfish.altavista.com is your friend. Lots of DIY guides, stats, FAQ's and guides in thelinks above.
  • Replies 99
will be taking some tomorrow, I borrowed Marcs digital tonight
When do you get your new rocket???  What are you getting?  Or is that a stupid question...
Cheers
Gary
soon gary ... soon...... :)
i might even pop by your place in it to return you the tape :headspin:
the 34 GTR front does bolt straight on, and it looks very very very nice there are a few getting around in Japan.  It was the original idea but I like the idea of people not knowing what it is...The ultimate sleeper
Heheheh. . too late dude.. anyone that has followed/have knowledge on nissan imports would know the details of your car.. :)
Tho the uprated RB26DETT version (?) now.. that is the ultimate sleeper! heheheh :)
Still that is one sweet looking car you got, keen to come out on one of the cruises? Wouldnt mind having a look. ;)
Saw it today.. strange looking creature.. but driving along without a close look you would just think it was probably a volvo. Except when you see the nice engine lurking under the hood :D
I love the little unicorn "S" badge on it ;)
Hi Gary, good to see another Stagea on the go. Mine arrived 5 weeks ago and is still getting complied. Typical Nissan problem with rolling updates, where they use some new model parts at the end of the run of old models. In my Stagea's case that was a rear left hand door, it has the later model intrusion bars and all the other 3 doors have the early model intrusion bars. So it is stuck in no man's land with the beaurocrats at DOTARS. Hopefully it will be sorted out next week. We have a race meeting to go to next weekend and I need the Stagea tow car.
I have some plans for our Stagea as I have some good bits coming off the RB20DET in the R32 GTST, as it is getting a new RB31DET; :cheers:
GCG ball bearing hi flow RB25DET turbo
Performance Metalcraft split dump, engine pipe and hi flow cat
3" exhaust
FMIC and alloy pipework
Jamex panel filter and CAI
Autospeed (2 valve style) boost controller
Since it's an auto, I will have to make do with an SAFC for fuel tuning and no doubt it will need a set of Koni adj shocks, some adj to the caster, decent brake pads and a set of Hollow Type R's in 17 X 8. Not to mention a HR towbar and a big transmission cooler.
I am looking forward to seeing what others have in mind for their Stagea's. ;)
Sydneykid,
They are a great vehicle to own. Seems like you and I are doing the same sort of mods....
turbo ,FMIC, exhaust, boost, suspension. I am converting mine to manual in the next week or two, already have the gearbox just have to sort out the rest of the parts I will need, seems everything needs to be 34 GTR ( my wallet hurts ) or RS260 ( now wallet really hurts ). The only other mod I will eventually doing is the RB26 swap and all the computer bits and pieces as well as the brake upgrade and a little body styling. At the end of it all should look nice and go like the clappers, just what every family wagon should do...
Would love to see pickies of your car when you get it.
Cheers
Gary
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
