Due to unforseen circumstances I have had to sell off parts from my uncompleted project.
Firstly the engine:
RB30DET
RB25DE stock head full reco with 110lb valve springs
RB30 block sonic checked and awd machined, with machining for tensioner pully relocation
CUSTOM side feed intake plenum with trumpets inside cost $1350
CP pistons 86.5mm
Spool Rods
ARP main, rod and head studs
NITTO OIL pump
NITTO crank collar
ROSS metal jacket balancer
NPC 10 inch clutch
TOMEI 1MM oil restrictor x 2
TOMEI SUMP baffle
HI OCTANE RACING awd SUMP adaptor.
NISMO engine mounts
6BOOST manifold
TIAL 60MM wastegate
BORG WARNER EFR 8374
DENSO 650CC low impedance injectors
TURBOSMART FPR800 with fuel pressure gauge
Custom Dual entry fuel rail
$700 of braided Teflon line for turbo oil feed, 2x water and 1x return.
YELLOW JACKET cool packs.
GTS4 AWD SUMP with 4.33 diff.
Engine is new! Has not been run yet! Looking for $16000.
Runs CP file back rings
ACL RACING big and mains bearings at .25
FULLY BALANCED ENGINE, engine pistons are also machine fitted to its specific bore and balanced accordingly. Machine work alone was $3500.
Also rebuilt r32gtr box so now 4th gear crunch $900
APEXI A.V.C.A.R $400
3INCH MAGNAFLOW 100 CELL CAT.$120
Walbro 040 $120
Fully rebuilt r33 GTST brake callipers full set $800 with rotors and new Lucas pads
https://www.sau.com.au/forums/topic/445561-rb30det-awd/
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
