So for sale I've got a pair of garret/hks gtrs turbos, they've only done 12,000kms in good condition no shaft play
Hks pulse exhaust manifold , with no cracks
Hks dump pipes with new o2 sensors
Apexi bends with pod filters and standard air flow meters in good working condition
Xforce crosspipe 3.5 inch stainless steel
Brand new never used genuine Bosch z32 airflow meters with plugs.
Standard exhaust manifolds with no cracks
Standard oil lines and top turbo piping.
Nistune ecu
All this gear is to suit a r32 GTR skyline and is in good condition!
I'd like to sell all this stuff as a package deal but if I can't sell it after a few weeks I will sell stuff separately
$3500 Ono I live in tasmania and will post Australia wide at buyers expense. More pictures can be supplied if needs more
Call peter on 0438308757post-134876-14052035041128_thumb.jpgpost-134876-14052035181152_thumb.jpgpost-134876-14052035393171_thumb.jpgpost-134876-14052035593099_thumb.jpgpost-134876-14052035775768_thumb.jpgpost-134876-1405203592592_thumb.jpgpost-134876-14052036062525_thumb.jpgpost-134876-14052036244667_thumb.jpgpost-134876-14052036416774_thumb.jpgpost-134876-14052036676331_thumb.jpgpost-134876-14052036793331_thumb.jpg
https://www.sau.com.au/forums/topic/445566-gtrs-turbo-upgrade-kit/
Turbos $1100each
Hks manifold $500
Hks dump pipes with O2 sensors $400
Apexi pod filters and bend and standard afm's $250
Z32 afm's $475 for the pair
Nistune ecu $400
Stock piping and oil lines $120
Gtr r32 intercooler good condition , no brand $250
Gtr injectors 444cc good condition and in good working order $250
Also have for sale a r32 GTR hks hard pipe kit for the intercooler with joiners and clamps $250
Sard fuel reg with gauge$150
Twin 044 pump holder $30 ( brand new)
Will get some pics up later this morning
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
