Bride \ Recaro Express Group Buy #2 "replica" Seats Carbon , Kevlar ,frp ,glitter
suwidji : Vios III is fixed back , The one you linked is a low max style with plain cloth. Universal rails are not direct bolt on as you need the mounts customized.
Can I grab a Bride Low Max Gias 2 Black back with the Normal Bride Gradiation like in photo 5 and standard size.
Please and thanks. Also need my sent to Brisbane not Sydney. :)
Longz : Bride Stradia Alcantara , Bride Low Max Gias Alcantara
smg084: Stradia 2 Sport Style-frp
lokiR33 : BRIDE STRADIA II - FRP Black
Jezr: Bride Stadia II Maizora Graduation Fabric
BLK-51N : Bride low max gias 2 FRP back in black gradation standard size
green180sx : Bride Low Max Gias 2 - Kevlar purple stitching black floral writing **
Abdul11 : Bride Vios III FRP Red -
Cxxo : Bride Low Max Gias 2 Black back with the Normal Bride Gradiation **
First round of seat's will be ending soon.
I am currently in talks still in regards to the XL seat's which will be sent in a 2nd lot.
Will keep this thread updated.
Bride ViosIII - Glitter (XL Size)
Bride ViosIII - FRP (XL Size)
Bride ViosIII - Carbon (XL Size)
Bride ViosIII - Kelvar (XL Size)
BRIDE VIOS III - GLITTER Black Alcantara (XL Size)
BRIDE VIOS III - FRP Black Alcantara (XL Size)
BRIDE VIOS III - Carbon Black Alcantara (XL Size)
BRIDE VIOS III - Kelvar Black Alcantara (XL Size)
BRIDE VIOS III - VENUS Black Alcantara (XL Size)
Bride StradiaII - Glitter (XL Size)
Bride StradiaII - FRP (XL Size)
Bride StradiaII - Carbon (XL Size)
Bride StradiaII - Kevlar (XL Size)
BRIDE STRADIA II - GLITTER Black Alcantara (XL Size)
BRIDE STRADIA II - FRP Black Alcantara (XL Size)
BRIDE STRADIA II - Carbon Black Alcantara (XL Size)
BRIDE STRADIA II - Kelvar Black Alcantara (XL Size)
BRIDE STRADIA II - VENUS Black Alcantara (XL Size)
Price's should be similar to the normal ones just about $50-60 extra per set i can get the exact amount when order is going in as they take USD and our $ is terrible.
^ im bad at econonics but can you explain wtf is going on ? We were at 94c how did it drop to 88c and going a futher 3c lower? Will we ever recover
Haha I'm not that good at it and I don't know why. I just keep a eye on it for work, mainly hear stuff through my boss as I work at a timber importing company, and basically everything we import is based around the dollar.
Its hard to follow unless your heavily involved as all sorts of things affect it.
I can tell you that timber products (decking mouldings etc) are about to go up. haha
Edited by Cxxo
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
