Hi guys,
New guy here looking for some advice on where to go next in my diagnosis.
I have a '96 R33 GTS-T pretty much stock, it started running a bit rough a couple of months back but i only just got off my ass to investigate it.
So i checked my spark plugs, found cylinder 6 was black/ oily. I did a compression test, the first 5 cylinders showed 120psi, but the 6th cylinder showed only 20psi....... yes, 20. We didn't have a proper cylinder leakage tester but i had a connecter and plugged an air line into the spark plug bore with the engine at TDC and air came rushing out of the pod filter.
So obviously there is a problem with the inlet valve/s on cylinder 6?
I was hoping you guys could give me some insight into what the actual problem might be and how i go about confirming and rectifying the issue? And will i have to replace rings as well? Im not sure where to go from here and how much work im looking at. I was planning on selling the car soon so i dont want to spend too much time and money on it.
Your input would be appreciated,
Cheers, Sean.
Probably be more coat effective to replace motor with a used lump with good compression since you're selling it anyway
Say of you pull the head then find out your piston ring lands are smashed, there's more money gone.
Sad reality isn't it? But these cars are old and they break
  • Like 2
Mine only broke due to some one else's boo boo,if you take care of your engine they last,nearly 300000 on second hand motor on my old 33
do 30000 plus a year on mine so they do last. :-)
Mines probably got 300000 km on it too - judging from the body and car bushing etc. Clock says 140000 lol
Has had a good hair cut from dealers and previous 50+ owners.
I'm too scared to do a compression test on mine in fear of getting sad. It cops a beating on the track and regularly sees 1.5bar through the motor. It's going to pop soon I reckon lol
  • Like 1
Mine is in a similar condition Johnny, 200,000+ks, goes through 2L of oil in 5k, the bores were very scuffed when I had the head off. It just refuses to die, even my tuner is amazed. It still cops 32psi daily, i'm not tracking it anymore but it survived 8 track days, overheating to 150c quite a few times, and over 200 power runs on the dyno... Some of which caused a head to lift.
The only reason I think it is still going at all is because I have a spare engine waiting to go in. If I sold it the engine would blow the next day. Regular maintenance, good fuel and tuning are my reasoning though.
To the OP, rip the head off, if there is anything wrong it's time for a wrecker motor I think. Make sure you can compression test the s/h motor in the car if possible, and check the oil filler cap and inside the rockers for carbon buildup which would indicate poor servicing with crap oil.
your motor is just scared of being replaced so it's behaving LOL
it's sad we will never truly know the real KMs on these import unless it's come straight from Japan with authentic japanese deregistration & auction papers
Just because the engine was at TDC doesn't mean it was firing on No 6.
Could just as easily been firing on No 1 which could explain air rushing from No6's inlet valves.
To eliminate the guesswork, one would rotate the crank another rev and perform the test again.
Then you'd have a better idea if it was a valve or a piston problem.
No matter in the long run, 20psi compression test is a mega fail.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
