Thanks for the quick replies, from the sound of it, it is pretty simple? Is their anything else that needs to be done in order to drive RWD? Or simply hook up a switch to turn the "Attessa" fuse on/off??
From the last post, I'm guesing you mean that the car will always drive in RWD until traction is lost, then AWD kicks in?
The reason I am asking this is because I might be able to pick up a GTR fairly cheap, but i would still like to be able to drift it without too much hassle.
Would their be a big traction problem?
I know this sounds stupid, but I'ma noob to skylines.. When you say take the drive shafts out of the front, are you joking or being serious???
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-911957
There is a little bleeder thing on the clutch pack for the ATESSA, if you are intending to make it really RWD then it is worth cracking that open (watch out for fluid).
Also for a drift car you would want to get a HICAS (4WS) lock.
p.s. You can take out the driveshafts and it would save weight.
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-911985
If you are planning on driving the car for a long time with the fuse out then you will burn out the transfer case unless you pull the front drive shaft out. And anyway you dont need to *** around with changing it from awd to rwd as the gtr already does this so you dont need to *** around with it in the first place.
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-912421
The reason I wanted to **** around with the AWD to RWD is because I would still like to slide the GTR, without having the front wheels working giving me more traction to make it harder to slide.
Most would say just buy a GTS-T, but if I can get a GTR for a good price then I would rather one of them :)
I will definately email "skylinegeoff" when I get the car over here, and thanks for those pics, I'm checking them out now.
Matt.
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-912454
Only bad things seem to happen when gtr owners decide to make their cars rwd when they are designed to be awd. 2 such examples i have seen recently have had a nice inprint of a light post on the side of the cars :) Needless to say these 2 cars are now NWD (no wheels drive)
LOL, is traction really a big problem when going from awd to rwd on a GTR?? And you can hit a pole sideways in any car really, all depends on the driver and how stupid they feel like being.
Matt.
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-912477
1) Maybe try www.Autospeed.com, I know they have an adjustable gadget that controls torque from the front to rear.
2) As far as making drifting a GTR.. sure it's not as easy as a RWD, but it's as simple as popping the clutch, and alot more easy to control than a RWD. But of all GTR's the 32 is this easiest with it's known rear wheel bias.
I agree with INASNT, start stuffing around with something that's designed for one thing can't be good. Most guys looking for a RWD option on GTR's are draggers, who switch to RWD to wam the rears before a run, the back to 4WD to launch.
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-912540
I'm not sure what would happen if you dropped the front drive shafts and left the fuse in, I'd guess that it wouldn't like it very much. Maybe ask one of the tuners on here or SydneyKid for a definate answer.
I would suggest you try drifting the gtr first before worrying about changing it. Plenty of 32 owners have been caught out with the amount of drift the 32 allows before the attessa kicks in...
cheers
Brett
https://www.sau.com.au/forums/topic/44622-gtr-awd-to-rwd/#findComment-912623
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
