Hi all
I'm looking at purchasing an R32 and i was wondering if there are any reputable workshops in Brisbane that know their skylines well that would be able to have a look over the car to tell me if there's anything majorly wrong with it?
Someone has informed me of a place on the gold-coast... but are there any in brisbane?
Thanks
Jason
When I bought my car I had John from Brisbane Tuning & Turbo at Woolloongabba look it over. Very thorough, and have had him working on the car ever since. He always has 2 -3 skylines in the shop at any one time. Worth a call.
I agree with EVO83...Rich at Allstar seemed to be very helpful...the effort he put in for the dyno day was excellent, plus he's happy to answer any questions and show you what's going on with your car.
Some people dont like driving to the coast.
Which is fair enough.
I'll be buggered if we'll take our car anywhere else though. Been ripped too many times by so-called "experts" before we found a reliable mechanic (gavin) so aint gonna change now to save ~30mins travel time (yayay southside massive)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
