ECR33 Airbox (No snorkel) - solid condition $100
K&N Air filter (used but in good condition) $20
WILL SELL BOTH OF THE ABOVE FOR $110
eBay steering wheel with 'Trust' horn button, quality is actually not too bad $50
S15 JDM injectors x 2 - brand new from Nissan and direct plug in for R33s $100 for both or $60 each
Apexi Pen style turbo timer - brand new with box $40
Blitz FATT, used $50
PowerUp dual stage manual boost controller $95
Can work out postage for items at buyers cost. Pick up in Doncaster/Toorak.
Feel free to make an offer, parts just sitting around so you never know your luck.
Edited by gtsttrk
https://www.sau.com.au/forums/topic/446590-r33-ecr33-parts-galore/
Is the boot from a sedan or coupe? and is the Apexi turbo timer genuine or fake?
Boot is from a coupe, and I presume the timer is genuine. I purchased it off a member years ago, came with the box, instructions etc. I couldn't fault it at all and would say that I'm 99% sure it's a genuine.
Wheel sold pending payment
Filter sold pending payment
UPDATED PRICES
ECR33 Airbox (No snorkel) - solid condition $95
WILL SELL BOTH OF THE ABOVE FOR $105
S15 JDM injectors x 2 - brand new from Nissan and direct plug in for R33s $100 for both or $50 each
Apexi Pen style turbo timer - brand new with box $30
Blitz FATT, used $45
PowerUp dual stage manual boost controller $60
UPDATED PRICES
ECR33 Airbox (No snorkel) - solid condition $90
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
