Can't remember of find the thread I was thinking about just vaguely remember someone talking about part of the engine that peeled when the car had a hard life. Is this the thing they're talking about? What is it?
I mean just cos theres no paint on this thing does it mean its a shagged RB26DETT?
Possibly my dumbest ever question but I had to ask :Oops:
Soz forgot to use my crayons.
https://www.sau.com.au/forums/topic/44700-good-indicator-of-rb26dett-condition/
oh i get it...the plenum. hmmm...dunno..hehe
i was also told to check the condition of the stickers with numbers that run along the wires closest to the engine. if theyre really shriveled then its an indication of a hard life. but then again were talkin about a 10+ yr old car here so who knows exactly.
Intake plenum with the stock fuel rail.
It depends... I'd reticient about really clean engines because someone might be hiding something?
Or do you just go with a dirty engine because the mechanicals are great and the seller doesn't want to hide anything?
I seen some 1996 GT-R's with peeling plenums - it's no indication of engine wear.
At then end of the day, I only trust a compression test.
T.
you would think that paint flake could be because of heat = meaning trashed out
but yes its a 10yr old car
i mean that is a good question because im looking at the 26 conversion to mine and i seen a half cut of a 26 and it looked like complete shit.
anyone else have something to add to this??
The stock plenum seems particularly prone to peeling. Personally I would look at the cam covers as well as see if there is any sign of them being removed. Not really a sign of "health" per se, but should give you an indication if someone has frequently been removing them to meddle with timing, etc.
Lucien.
I spoke to this engine rebuilder the other day and he was saying stuff about a compression test will only tell u a few things about the engines health at that particular point in time. He said that cars in Japan rarely go over 80kph and that when we get them here and go 100+ that sludge inside the engine can brake off and screw the engine.
I guess in that way its safer buying local cos at least u know its seen the highway and the "sludge" has reduced without causing engine probs. I call it sludge cos i dont know the correct mech term.
"Sludge" eh? This a technical term that mechanics use these days? Don't spose he had a few local delivered cars to sell you too :P
A compression and leakdown test is about as close as the average joe can get to checking the health of an engine without ripping the whole thing about.
With oils and lubricants replaced and driven reasonably softly for the first few days, an import should not be any less reliable. Slow city driving is not good for any car (compared to highway miles), but you would have much the same issue buying a car in Australia. Oh, and from what I have read, a lot of Japanese have a very liberal interpretation of their speed limits :P
Lucien.
The plenum in the first picture looks like it's been stripped on purpose, quite amateurishly, without being removed.
It can't be a case of paint peeling off, as there is no paint left on it.
However, the whole engine bay is quite dusty which can mean a number of things.
Possibilities are : The car has been sitting in storage for a long time, the owner has never opened the bonnet, the owner opened the bonnet but can't be arsed to clean it, etc... I certainly do not spend any time cleaning my engine bay. The appearence of an engine bay can reflect its mileage or fastidiousness of its owner but not its condition.
If it's a local car, get it checked.
If it's not a local car, get it checked.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
