My dyno printout - Sat 26th (Cyrus put yours in please)
Anyway guys....here is my chart from Saturday at AllStar with the Zed Club.
See if you can spot where the A/F ratio was lean enough to make the car ping, retard timing and bugger up the rest of my run :D
Anyway the power figures are low...apparently this can be confirmed by most people that use the Allstar dyno....but as everyone knows they're a tuning tool, not just for horsepower queens :( I did manage 97Kw on the first run...but as mentioned before, it started to retard quite badly.
I've adjusted my AFRs so the Mercury Motorsport weekend should be better for comparison reasons.
I was told not a bad effort considering I've still got the N/A exhaust fitted...hmmm back-pressure!
  • Replies 41
Mine got 266hp (198rwkw) on a dynonamics dyno on monday 10 May 2004 and then got 165rwkw on the Dynologics dyno on 15 May 2004.
It's just the different type of dynos and how they measure the hp/kw. I heard that dynologics is more accurate with tuning but dynonamics is better for power runs.
*shrugs* I personally like the higher figure myself :D
Damn Dyno Queen :D I really need to get my exhaust sorted out....until then I reckon I'm stuffed for any decent power...she still goes good though...enough to keep a lot of turbos at bay.
yeah managed to sort the AFR leaning-out while on the dyno...had the trusty laptop with me. It's not too horendous...most of it is in the region of 12-12.5:1 It's the power delivery that has me stumped....it's just so flat....I was hoping for some sort of curve.
is that the time i beat you erin :(
woa.. thats all over the shop. Sorry to say - almost n/a figures :) very linear there?
sir31 got 88rwkw from ye olde SOHC RB30E .. http://forum.r31skylineclub.com/index.php?...10913.0;id=1327 same dyno a few weeks ago..
Cyrus is away on an Island , think he's back tomorrow , on the same Dyno 101 rwkw this time he ran a 116 rwkw only diff is MY ( he is lending it ) Hks Super Dragger .
And now I don't even get to use it , o'well I least I could hear how it sounded
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
