Did a bit of searching on here and google but couldnt find what i was hoping for.
Im going to change my strap setup on my car trailer, seen it on another car trailer at a meet.
Going to use square u bolts one before and after each wheel and run a strap on each side from front to back going under the ubolt over the tyre and back under the second ubolt for each tyre.
Going to weld in some square metal tube under floor of trailer for each ubolt to go through since floor is just mild steel 2or 3mm sheet, double nuts on each thread.
Does this sound ok?
Any suggestions on improvements or things to consider?
I think they are m10 or 12 ubolts just mild steel.
I was using 1 x 1.5t strap per wheel but when towing over to adelaide for sau nats last year the rear toe arm was stripped on one side, possibly over tightened or just from forces from 130kph travelling on shit roads, plus the straps rubbed on my rims and marked one of them.
https://www.sau.com.au/forums/topic/447203-car-trailer-tie-down-points/
That is a great idea.
I use that idea on my trailer as if ratchet straps are used incorrectly they can stuff your alignment.
I purchased some spring loaded fold down tie down points from a trailer place and welded them into the checker plate. I run two 3T straps over my front wheels and then back to a secure point for the ratchet to connect too.
The rear just gets two spare 1.5t straps through the rears (not too tight) just incase I hit any large bumps or jumps hehe.
I got the idea from a tow truck set up.
I have been looking into the same idea as I have found that the ratchet tie downs have been coming a bit loose on the rear of the car on smooth roads. It makes me nervous. I have been looking at all sorts of flatbed tow truck set ups for ideas and what you have mentioned is something that will also make it quicker to load/unload and safer.
Could you please post some pics of your set up BOZ22N?
Keen to see pics of what you end up doing?
We wanted to mod our trailer but settled for better straps... The straps have a wheel protector and are designed to pull straight down on the tyre and not against it... They seem to do a good job and are bloody easy to use :)
  • 4 weeks later...
Sorry for the super late reply.
This is my tie downs they sink flush in the trailer and then you just thread your strap through the rear one and fix the ratchet to somewhere.
My trailer needs some TLC but the system worked well for the few years it was being used regularly.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
