Hi, I have recently bought a stage 3 shift kit for my auto r34, I will probably get a medium stall converter. Is there anything else I am going to need besides a rebuild to the box also how will a shift kit affect gear changes and the way the car drives, stage 3 is the firmest you can get I think and I've heard that they can be pretty wild, as its going in a street car would it be to much, can I still just put the car into 'D' and go grab some Thai noodles on a Friday? WILL IT STILL BE STREETABLE?
Thanks J
https://www.sau.com.au/forums/topic/447296-shift-kits-auto-box/
Shift kits are just kits that put higher amounts of pressure through your valve body making the vehicle shift more "positive" so to speak. The shifting will be harsh when cruising, kind of like a kick in the pants and it might even let off a little churp. Your stall converter size should be coming in when your power comes in, so lets say your cars power band is from 3 - 7500. Your converter would need to be 2800 - 3200 or thereabouts.
It would still be streetable, but will chew more juice because of a stall converter. You are still able to drive the car in D unless you have a semi manualised or a fully manualised valve body, then you'll need to manually shift from 1 2 3 D or whatever pattern your car has.
As Ben stated, a decent sized trans cooler is a MUST when it comes to stall converters and stuff.
Hmm thanks, as to bens comment Ive worked with auto boxes before so Im building it myself, but mainly 727 torqueflytes and 904 boxes out of valiants and dodges so old school. Just out of curiosity what happens if I don't upgrade the converter, say because I wanted to use less fuel. As a street car I'm not going to be stalling it up, so is it necessary. Also the shift kit goes into the existing valvebody if I'm right, so If I have a normal valvebody (the r34 has the triptronic or whatever its called where it has the sideline so you can choose gears semi manually) it should be able to be used in the same way? Ill definately be adding a trans cooler anyhow.
Also as the factory trans computer is staying in place shifts are still reasonably nice at light throttle due to the trans computer reducing line pressure. It's only when you go full manual and run full pressure the whole time that shifts become very harsh all the time.
Is there any info anywhere as to how much the standard computer modulates line pressure? Does it go for "X" PSI or does changing the valve body result in it working in a "percentage?"
eg, at 'low' load does it go for "50%" of line pressure, or a set PSI?. I am kind of assuming it does a percentage, otherwise upgrading a valve body would do literally nothing if the standard computer would control exactly how much pressure to shift with :P
What you want though, is an aftermarket TCM for your transmission. Hopefully I will be able to see what the difference is running a big shift kit on the standard computer to one with a tuned TCM.
In all aspects though, a big shift kit is usually just fine for the driver, passengers may complain, though. This is the case with almost any modified car mind you..
  • Like 1
From what I understand it does it by pulsing a solenoid to bleed off pressure.
It doesn't monitor what the actual pressure is, so its just a set duty cycle thing.
You can add add larger resistor into the solenoid wiring so it bleeds less pressure off by not allowing the solenoid to open fully. At full throttle it's full line pressure so it just adds pressure for part throttle stuff. I did it as I run an rb2530 so make more torque with less throttle openings than the stock trans ecu would be expecting.
Edited by Ben C34
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
