Hi Guys,
Thought you guys could help me with this.
Getting a GTR complianced and apprently there is a problem with xenon bulbs in the R34 - they are not auto-leveling and hence need to be converted to regular lamps. Ok fine, but when I asked the compliancer to give me the bulbs when he has finished the conversion he said he has to destroy them under government policy. He even mentioned that they will get audited in regards to destroying parts that need to be replaced on cars for compliance reasons.
I personnally think he is yanking my chain - how the hell is the government going to audit "garbage"? Will the compliancer need to keep an every growing pile of "useless" parts until he gets audited?
I just want to know what I should do. I figure the car is mine/the dealers before the compliance, therefor anything removed from it still belongs to the owner.
Thanks guys.
The complier is absolutely correct, they are only allowed to comply totally standard cars and non-standard bits have to be destroyed...and they need proof that they were destroyed.
However....it was really brought in to stop ppl having a big turbo or similar, pulling it off for compliance and then putting it back on straight afterwards.
As I understand it your best solution is to put standard lights in before it goes to the compliance workshop...then neither you nor they have a problem....
I'd make sure I was standing when he destroyed the bits, never know could be making big dollars selling them off on the side (some shonky people are still about!).
But yeah I'd change them out before it got complied.
i imported my skyline under the new import rule and i didnt get anything destroyed...car was put totally bak to stock...then i paid him just the labour to stick everything bak on after it passed the blue slip....doubt the goverenment cares if u have them or not they are more worried bout it bein complied with stock parts so it cost the buyer a shit load to change things bak and forth...
oh yeh i forgot.....wen i took it to the RTA road worthy centre place to ge it all checked out.....the guy didnt even notice that the racing arms were left on wen he checked the underbody and that it was missin the R33 S2 air box not the S1 air box.....shows u they dont really now wats meant to b on an import and wats not...
Pentae didn't u buy a R34 GTR? i'm sure GTi-R's never came with Xenons unless after market...
And there is more to it than just changing "the lights" If you swap bulbs, powerpacks must be un-hooked and new ones put in for halogen bulbs. Otherwise, 4 door R34 halogen light ASSEMBLY's are needed. The entire headlight assembly. Can't just throw halogens in.
My compliance place isn't sure what they're doing with this yet, i told them there is a evidence package around for swapping powerpacks and halogen bulbs. So hopefully, i can keep em.
cheers.
Gohan: No, didnt end up buying the R34 GTR.
My GTiR I purchased at the start of the year came with aftermarket Xenons.
flight: I'd say your compliancing house is just trying to go by the rules. It would be a national tragedy to not pass compliancing on a $80,000 GTR.
cheers.
The compliance place I am using is modified the existing assembly to accept halogens. Unsure about which specific components are being changed/removed. I will find out because inevitably I will be changing them back to xenons. Just want to find out how much it is going to cost me.
What do you mean by evidence pack?
thanks!
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
