Hi everyone, for along time now I have been an avid reader of these forums and love every part of these forums. I am new to the Nissan scene so I have been trying to learn a much as possible. I do not post much as I feel I don't have much to say compared to some of the gurus here. (There are some very smart people on these forums).
but this brings me to my dilemma.
I have a 2004 350GT8 Sedan CVT-8 (8 Speed extroid (JATCO JR006E)) with transmission problems. :unsure:
Now I know this transmission has parts that are harder to find than Unicorn Poop and I know that what I am about to ask is nuts/crazy and ALOT of work, BUT.
Does anybody have any parts, old transmissions, failed attempts or anything in regards to parts for this box or its close cousin the RE0R04A 6 speed CVT .
We have the JR006E apart and have found that the required Item is one roller. We have a great chance of actually fixing this.
Below are some photos of our mission so far, I post these pics in the hopes that someone will recognize this transmission and will have parts laying around from an old attempt at repair etc.
I also post these pics as when I did my research the only photos i could find that helped at all were from "Sbyder" on these forums, THANKYOU by the way http://www.sau.com.au/forums/topic/256370-nissan-extroid-cvt-strip-down-and-repair/
I hope that if I at least cant be helped that maybe these photos may help someone instead. Thankyou SAU and all involved. :yes:
All these photos are full Resolution ((PS. I have no Shoe on because A bee Stung me))
Please don't hesitate to call or Email me 0433208159 or [email protected]
Edited by Subs
https://www.sau.com.au/forums/topic/448433-cvt-8-parts-call-for-help/
  • 3 weeks later...
Subs I am in Sydney and actually in the conversion stage CVT to 6MT....... If you like you can purchase complete transmission of me for $400. But you would have to arrange pick up. You can reach me Adam:0435729442
  • 10 months later...
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
