Hi guys , just wonder if there is any one who has a spare valve body for a C34 S2 triptronic box in Melbourne , as MV auto`s want $400 deposit plus the price of the body which is way over the top. I only need it until I get the change over unit back from Adelaide. thanks.
https://www.sau.com.au/forums/topic/448496-valve-body/
Fair enough too, I just returned the only spare RE4 valve body they have left, as apparently us Stagea blokes don't return them if they only ask $100 deposit.
You ARE getting it back after all. ;)
Who's doing the install for you? I have an entire RE4 from a 34 here I could perhaps sell you cheap.
https://www.sau.com.au/forums/topic/448496-valve-body/#findComment-7386651
sounds good to me Scotty , Its actually for Adams silver 34 , not sure who is going to do the job , any recommendations ?.
I`ll give him a ring and come back to you .but I would probably say yes at this stage , That reply was what they told adam too and hence the price hike.
Edited by coparts41
https://www.sau.com.au/forums/topic/448496-valve-body/#findComment-7387109
Dunno if Scotty would mind me suggesting Scotty's Customs for the job as he did mine for me while it was on his hoist getting a custom 3" stainless zorst. They put the money back into your account the day they receive it. As Scotty mentioned apparently they have 10 around Aus that no one has bothered returning. I was waiting for mine since Christmas. It's worth doing though, on my rwd it chirps first to second in D. Scotty also bulit me a fantastic exhaust too. Don't mind saying I like getting underneath to look at it a few times.
  • Like 1
https://www.sau.com.au/forums/topic/448496-valve-body/#findComment-7387183
Well here is the progress , valve body arrived from MV automatics and we decided to do it ourselves . Used a mates hoist , changed the valve body , 12 ltrs new oil and 3 hours work and all done .
It has changed the car dramatically from a slush box to a real nice feel on gear change , no delay slip or any nasty stuff , just real crisp change . Well worth the money . the end .
  • Like 1
https://www.sau.com.au/forums/topic/448496-valve-body/#findComment-7394018
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
