Hi guys just after clarification. Unigroup tuned my car and suggested to run the narrowband output. Ive set my wideband to p4 and it puts out approx 0.1 to 1.1v. Now if i am correct ill need to connect this to the clear wire on the o2 loom in the engine bay. I do not want to splice the wiring near the ecu.
Is the voltage given out by the narrow band safe for my ecu? Some say 0 to 1 v but if ive seen 1.2v coming out i dont want to fry my ecu.
its an r33 gtst with pfc.
https://www.sau.com.au/forums/topic/448617-aem-uego-narrowband-output/
What do you mean by narrowband? Have you got a Lambda sensor (wideband) that also has a narrowband output? If so the latter should be fine for your ecu. Having said that like most people running a Link I have ditched the O2 sensor as the Link can be tuned to take care of everything. Not sure about PFC
Its a lambda sensor but the AEM unit will simulate a narrowband output.
Unigroup suggested to run it in there and switch o2 feedback on as it can improve economy if I am doing mostly cruising driving, which I am.
Plenty suggest ditching the o2 sensor all together and letting a good tune handle everything. These guys suggested it will do no harm to have it in there and enabled as it won't hinder performance at all and will either have no effect or some effect to economy.
I've still got a near new o2 sensor here and a bug but don't really want to put another unit in the exhaust.
Yes it's fine, I've setup the same thing for many people and removed their stock narrowband - I usually just splice it on the ECU harness to keep all the wires inside the cabin.
Just set it all up. Damn those wires for the o2 sensor are brittle as shit from the exhaust and turbo heat. All the shielding is dry and crumbly lucky i saw it.
Cheers guys. Next on the list is fuel pump and beefing up the power.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
