Hello Everyone.
Please help me identify problens with my gerabox.
I have a BNR32, with nice built RB26 and S362FMW runing 1.2-1.4 bar of boost.
I have broken 2 sotck trannys so i ordered OS-giken 5 speed kit with input shaft and center plate.
Installed it and my problem seem to go away... until i get to drag strip.
While making my starts better and better tuning launc and torque split finaly i set up launch to 7200 and forgot to remove 50% fo torque from front i didn ont start at all, the car didnt even moves.
later in garage we found that it is counter shaft broken right after 5 gear.
Here is a picture
If you look closely you can see wear on the shaft in the place it inserts into a wall between gearbox and transfer case.
What can be the cause of this? I mean the cause of breaking shaft i guess wear shows that shaft was not proppely secued and had a play.
All kind of bearings including bush in the crankshaft?
Edited by Peacekz
You haven't listed your power, which really tells more of the story then how much boost you are running. Depending on power/torque, with a 7200rpm launch with power going to all 4 wheels, it might just be something that should not have been done.
Better photo of the fracture?
Hello Sorry no better foto.
I dont know exact power. it should be around 600 HP i think taking in consideration i load 89% of 720CC injectors and making 11.4 ET with bad start.
Soru english is not a native, what do you mean by fracture? the place where i see a wear on the shfaft where it contects needle type bearing or the photo of the the shaft where it was broken?
Yes i understand that was my mistake to launch on 50/50, but i'm quite expiriencde in gt-r's and never seen countershaft failure like this. There is always a weaker point than these solid 29mm stell shaft.
The middle shows the last part that hung on then twisted and snapped. Will have to find my failure analysis book, haven't had much to do with metal failures lately. That is a very clean break. I had a similar looking failure with a rear drive shaft. Almost identical actually.
That was from a high rpm launch
Edited by 89CAL
One more thought -the break surface is polished by rotating during the car was worked. And we pulled the car to the garage with the engine started so the brakes was good. So i guess the surface will not tell the truth. I guess the shaft was broken due to it has a vertical play.
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
