Hey guys.
The stag was starting to show signs of the turbo failing so i have entrusted R&D to pull it apart, Hypergear should be doing the Hiflow & Scotty the new pipes.
The trans will most likely be next but i would also like to start getting an idea on ECU options for retuning.
Ideally id like somthing that can be riged up to a tablet in the pop up screen section as the screen is still jap and gets no love. Was also curious if there is anything around that will let you have 2 different tune setups, one for daily economy and one for power.
As always, any info is greatly appreciated!
https://www.sau.com.au/forums/topic/448721-m35-ecu-piggyback-units/
there is 3 main options out there.
1 - Emanage - cheapest option and what most people are running.
2 - F-Con - fair few people have done these and there is actually a plug and play harness for the m35 (it is discontinued though)
3 - Adaptronic (stand alone ecu) - so far i am the only person running this but has been good to me.
It comes down a little to who will be tuning it etc also how far you think you may take the car.
Do a little research on them all and see what suits your needs the most
I'll eventually have my results up from my M35 build but it will be a couple of months off yet.
I'm going the Emanage/ss2 hypergear + supporting mods route so during my month off in November hopefully I can provide results. I live really close to R&D so hopefully they can help with some of my tuning decisions. Once sorted i'll shop for a bit more bracing and probably fit some decent brakes.
I'm sure you are aware that the jap screen can be converted to english (do a forum search) so it's not entirely useless. Also a forum member fabed up a 3 gauge holder mould to replace the screen all together...
Food for thought.
Cheers
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
