I have a stock R33 Gtst and I have been shopping around to see what type of exhaust I should get.
It seems every where I go I get given different advice.
it is starting to get confusing.
Drift King tell me they recommend a mild steel exhaust HPC coated.
others tell me stainless is best.
then there is those that tell me a single pipe for the dump pipe and others that tell me to get a double dump pipe with a seperate pipe for the waste gate gases.
Some tell me that the stainless systems sound to tinny!
Can any one help me ?
what seems to work the best?
any one know a good place in Brisbane ?
any help would be appreciated.
thanks.
https://www.sau.com.au/forums/topic/44928-suggestions-for-a-r33-exhaust/
get a custom job, mine works like a dream, it really purrs and is a loud exhaust at all.
get something like a 4inch dump into a 3.5inch pipe then shortening into a 3inch (or can u get 3.5inch cats???) high flow cat then 3.5inch pipe all the rest of the way
just my suggestion anyway...
high flow cat
3 in exhaust. mild steel with HPC coated.
stainless are stronger, so are allow to using thinner pipe, hence lighter. But then most of them are shit so mild steel are always money for value.
Yeh I've been looking for an exhaust too, particularly the split dump pipe. Had trouble finding one cheaply, but I don't think it'll make that much different if you're keeping stock turbo (like I am). So I just settled for a standard dump/front pipe in one (no split)...check the forsale forums for BATMBL's thread.
  • 1 month later...
A mate of mine has custom made allot of exhaust systems and we have found the best way to go is a full stainless with a split dump pipe wastegate merging apout a foot down, a single 3' straight through muffler (marathon) with a cannon on the end. sounds great and doesn't drone.
Stainless is great it'll never rust out other wise there are some fairly good titanium or stainless systems around available off the shelf.
Nozila I bought a stainless pipe, and at the moment it's sitting in my room because I want to purchase the rest of the exhaust (cat-back system) before I install it.
But if I had the chance I'd probably buy the mild steel version instead. Cost, as well as I can't really see the pipe rusting anytime soon (although I have no conclusive evidence to back that up, just my feelings).
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
