  • Replies 60
you want some more!?!?!?!? well do ya!??!?! hehe... vids will be converted to digital format soon, then mpeg'ed to vcd. i wont be releasing them on my site for obvious reasons ;) tell me who wants a copy and i'll lob one to ya...
DR-Drift: a wounded car still keeping up with ya! :)
GTR UPDATE: looks like major upgrades will have to wait... only an intercooler hose came off... dunno how we missed it :eek1:
haha.. oh well its all good then ula! good to hear it wasnt anything major mate
Guest INASNT
Originally posted by poyz
Man, everyone in this thread is sick...
I'm keeping away...
yeah sick in the head!! hahaha
POYZ i had a run with a GTi-R like yours last saturday on the way back from race pace after my tune and he was on my arse all the way down stud road. we came to a set of lights i took off slow in first, punched it in second and pulled away about 4-5 cars on him by bout 160km/h! :)
Maybe he wasn't trying :)
You did a 14-15 1/4 mile right? a GTi-R with typical "turbo" mods should be doing 13-14 easy :P
POYZ i had a run with a GTi-R like yours last saturday on the way back from race pace after my tune and he was on my arse all the way down stud road. we came to a set of lights i took off slow in first, punched it in second and pulled away about 4-5 cars on him by bout 160km/h! ;)
speaking of sick, one of my mates died yesterday arvo of meningacoccal... it feels very wierd, coz i'd never have guessed it'd hit one of us, n so fast as well.
Guest INASNT
You did a 14-15 1/4 mile right? a GTi-R with typical "turbo" mods should be doing 13-14 easy ;)
I was doin 14.5 but calder to a normal road is quite different, i can get way more grip on a normal, and calder was without the s-afc tuned! and he was tryin very hard or else he would not have tailed me again after it! He was a P plater and all they wanna do is race!
Me 1 Gti-R 0
he lives around my area so i shall race him again when i see him!
14.5 isn't slow, but it's not fast either...a reckon a similarly modded GTiR (to your car) will still be quicker down the 1/4 due to traction and power/weight.
Either way, there are plenty of GTi-R's running about nowadays, you might find me next to you one day. And trust me, I'll will try and race you.
I'll make it You 1 - GTi-R 20+
Cause I know you'll keep trying to beat me :)
Me 1 Gti-R 0
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
