  • Replies 60
you want some more!?!?!?!? well do ya!??!?! hehe... vids will be converted to digital format soon, then mpeg'ed to vcd. i wont be releasing them on my site for obvious reasons ;) tell me who wants a copy and i'll lob one to ya...
DR-Drift: a wounded car still keeping up with ya! :)
GTR UPDATE: looks like major upgrades will have to wait... only an intercooler hose came off... dunno how we missed it :eek1:
haha.. oh well its all good then ula! good to hear it wasnt anything major mate
Guest INASNT
Originally posted by poyz
Man, everyone in this thread is sick...
I'm keeping away...
yeah sick in the head!! hahaha
POYZ i had a run with a GTi-R like yours last saturday on the way back from race pace after my tune and he was on my arse all the way down stud road. we came to a set of lights i took off slow in first, punched it in second and pulled away about 4-5 cars on him by bout 160km/h! :)
Maybe he wasn't trying :)
You did a 14-15 1/4 mile right? a GTi-R with typical "turbo" mods should be doing 13-14 easy :P
POYZ i had a run with a GTi-R like yours last saturday on the way back from race pace after my tune and he was on my arse all the way down stud road. we came to a set of lights i took off slow in first, punched it in second and pulled away about 4-5 cars on him by bout 160km/h! ;)
speaking of sick, one of my mates died yesterday arvo of meningacoccal... it feels very wierd, coz i'd never have guessed it'd hit one of us, n so fast as well.
Guest INASNT
You did a 14-15 1/4 mile right? a GTi-R with typical "turbo" mods should be doing 13-14 easy ;)
I was doin 14.5 but calder to a normal road is quite different, i can get way more grip on a normal, and calder was without the s-afc tuned! and he was tryin very hard or else he would not have tailed me again after it! He was a P plater and all they wanna do is race!
Me 1 Gti-R 0
he lives around my area so i shall race him again when i see him!
14.5 isn't slow, but it's not fast either...a reckon a similarly modded GTiR (to your car) will still be quicker down the 1/4 due to traction and power/weight.
Either way, there are plenty of GTi-R's running about nowadays, you might find me next to you one day. And trust me, I'll will try and race you.
I'll make it You 1 - GTi-R 20+
Cause I know you'll keep trying to beat me :)
Me 1 Gti-R 0
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
