Gday guys,
Ive just completed the install of a hydraulic handbrake in my R32 GTST, with Z32 brakes.
The question is, whats the procedure of pressure bleeding the lines with a hydraulic handbrake in there?
The way i did it was as if it wasnt there, just bleed the rear brakes like normal without touching the handbrake.
So its not right, theres lack of pressure in there some where. When i pull the handbrake i can feel the brake pedal go down with my foot on it.
Do i need to open both rear brakes and pull the handbrake?
Anyone out there done it with a pressure bleeder rather than two people.
Thanks
So you have it inline with the standard brakes? Sounds like normal behaviour for an inline hydro to me.
The way to bleed it is as normal, start from the wheel furthest away from the brake master and then do the wheel next closest to it(RL, RR, FL, FR)
Yeah in line, thats the way i bleed it.
Doesnt seem right though, as the fluid should be all the way through the system there shouldnt be movement from another component when using the handbrake, surely!
I always use 2 people to bleed brakes, so can't comment on whether a pressure bleeder will work.
I used to bleed the handbrake separately, and it always worked for me. Others bleed the brake system as if the handbrake isn't there, and it seems to work for them.
Here's a process used by some rally guys. Never tried it myself, but it seems to be a good last resort for when nothing else works:
the method used is to put foot on pedal (pump it a couple of times to get a pedal if necessary), pull up on the handbrake and THEN open a rear bleed nipple. Once the handbrake is fully up, and the foot pedal is down, lock up the bleed nipple. At this point, pump the foot pedal to bring the handbrake back to the down position. Do Not force the handbrake down with your hand as there is a chance that air will enter via the seals in the handbrake master cylinder. Using this method on both the commodore rally cars at home works a treat. I have also had other cars come over with "spongy" handbrakes, used that method and "presto" firm pedal and handbrake
Fantastic, thanks mate.
I think ill drive it a bit (hard with a track car), see if that moves a few things around then give the brakes another bleed. Hopfully that will remove the last of the spongyness!
Cheers
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
