Hey guys. up for sale is my 1996 R33 GTST. 137thou on the odo.
I've only owned this for about 3 months, and only reason I'm selling is because I miss driving a Subaru.
Car starts and runs great. has a small leak from the passenger side tappet cover.
car was imported in August 2004
$9k ono
loc. newcastle
Fully adjustable Cusco coilovers
HDI Boost controller w/ gauge
BEE*R rev limiter
dildo shifter
front strut brace
aftermarket cd player sub/ amp
sparco deep dish with quick release
3 inch tbe with seperate waste on dump
HKS premium cannon
pod filter with cover
lenso 17x9 +17 all round. 215/45's all round
Adjustable front caster
hicas lockout kit giving adjustable rear toe
locked diff
gfb atmo bov
have the standard GTST wing but i've taken it off
has a front mount but not plumbed up yet
Running 14psi making 185-190 kw
10451698_296415337225306_289921387870615
10557708_290741817792658_172489600174706
10559719_261478777385629_378309338978104
Located in NEWCASTLE NSW.
text's only please.
0409840683
Edited by mattyboy33
https://www.sau.com.au/forums/topic/449866-fs-96-r33-gtst-nsw/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
