Hey guys. So basically I was driving around and stopped at a set of lights and suddenly smoke vapour appeared out of my steering column (the plastic surround) this happened a few weeks ago once and just recently it happened again.
My indicator works but as soon as the flashing arrow is off I can still hear the indicating noise! Could this be the reason why there was a bit of smoke? A fuse screwed up? The car is a r33 gts25. The car has been driving fine and all other electronics work, the car also has an alarm system that utilizes the indicator bulbs when you lock and unlock the car, could this be another reason? Many thanks.
Edited by TommyR33
Take off the steering column covers. (Couple screws, piece of piss)
Look around all your wiring looms. Especially places where splices have been made.
The biggest give away is electrical tape. All the wiring is pretty well in your face once the covers come off.
The smoke may be coming from further down in your footwell and the smoke is just making its path up and away out of your steering column section
When you say you can still hear the indicator noise is that permanantly or stays on for a little while?
It definitely sounds electrical. Do you have an aftermarket turbo timer in the car?
Has the person who installed the car alarm made proper electrical terminations or just twist a twist and tape job.
It probably wouldnt hurt to double check all your fuses too.
More of a look and discover type thing really. With any electrical fault be careful though. No one likes shorting out wires and blowing up the pcb to your mongoose alarm hahaha
Thanks so much for the help! Basically what happens is I indicate and when it switches off the ticking sound stays on and almost at a faster rate of interval ticks. I went under near the footwell and fiddlled around with the plug that goes into the indicator box and now its stopped and is fine! I am no auto electrician Mick but there is electrical tape in many spots and some wires and plugs bunched up not connected into anything, I mean it all looks neat but yeah. Maybe get a auto electrician to have a look for me.
I had this exact issue on my '94 Bluebird.
Turned out to be inside the stalk, a small piece of plastic between 2 copper terminals had broken / melted so it was arching between them.
A small ziptie strategically positioned and trimmed down, with a spot of superglue on it, Fixed it better than new. :)
All good mate, happy to help. If you do decide to look into any connection further please do disconnect the ground from the battery. Forgot to say that but it pays off to be careful haha.
auto-elec might charge you an arm and a leg for small amounts of work but sometimes piece of mind is worth it.
I can save you the trouble of further investigation. It's the blinker mechanism. I've gone through two of them. Once the blinker stalk smokes it's finished. There must be something about the inner workings that fails and causes a short. Get a 2nd hand one and away you go. A new one would be even better.
Something that may interest you is the blinker relay under the dash. A square box with three wires. That's where your ticking comes from, quite normal. Be aware that the relay can go from time to time and may have been replaced by a universal relay. Some relays are 2 wire and others 3, one being an earth. Replace the relay with an original 3 wire relay and a new stalk, problem fixed. I did it myself but an auto electrician will put it in for you cheap.
Read the tutorial to remove the column cover and remove the screws holding the stalk. I can't remember what else there is as it hasn't needed replacing for years.
  • Like 1
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
