Hi guys,
Recently had my 32 Gtr on the dyno to fix an unrelated boost controller issue which has now been solved. However the problem is my car has lost roughly 150hp since it was first tuned.
Specs of my setup
Stock 26 motor
Type B Poncams
3582R
All supporting mods, Exhaust, Fuel etc.
It was tuned on a hub dyno originally and made 510hp at the rear. Just recently my tuner has bought his own roller dyno which is what my car has recently been on. Obviously you expect some power loss because of the different dyno (he has a few other cars which have been on the same hub dyno as mine and they have experience about a 10% drop in figures). So now im trying to figure out how my car has gone from 510 all the way down to 365.
I have checked the following things;
-Ive removed each piece of the exhaust and checked for blockages and there is none (no cat)
-Ive done a compression test, 152-158 across all cylinders
-Ive taken the timing cover off and rotated the engine until the timing marks on the cam gears lined up with those on the head. Not sure if there is a way of me getting the motor to TDC without being able to see the gear at the bottom to ensure i have checked that the belt has not skipped a tooth? The belt and tensioners etc. were changed prior to the car first getting tuned.
When the car was on the dyno there were no obvious reasons as to why the car had lost power. It held boost fine, AFR stayed constant...Tuner said between 7 and 8k rpm it started to break down a little which may be because of the stock coil packs, but couldnt cause 150hp difference.
I've run out of ideas and its doing my head in, so any suggestions would be great.
Thanks
https://www.sau.com.au/forums/topic/450685-gtr-down-on-power/
I'd suggest, unless it feels significantly slower than it used to, that it hasn't lost any real power.
Trust conversion/comparisons between dynos at your peril. If the ignition timing is the same, the boost is the same and the AFRs are the same, and there are no blockages or boost leaks, then the power shouldn't be much different.
One thing you didn't say you'd looked for properly was boost leaks.
I recently lost a lot of power on my car and did all i could to get it back. Timing was bit retarded and advancing it got a lot of it back.
BUT then I did my service which was overdue - plugs, oil flush/ new oil, oil filter, new air filter - BAM a completely different car!
Service - a simple overlooked thing. Do it if you havent/
Edited by rondofj
I can see what your saying with comparing dynos, I'm just concerned because the variance is so large. In terms of boost leaks, couldn't hear anything when it was on the dyno and held boost fine. I'll have a closer look at the intercoooler pipes and stuff anyway. Car was serviced probably less than 2k ago. Good tyres and good clutch. He has just had another gtr on there, had - 5's, similar cams and 17psi...made 370? Does this sound about right or should it be more also?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
