Hello friends and fellow car enthusiasts,
I understand that we have not had any ACT cruises this year, which is quite sad given that ACT is the greatest state and have some pretty awesome cars and decent enough roads (kinda) So, hopefully we can sneak a quick cruise in before 2015 starts. We've got some new cars and mods with our fellow ACTers and it would be great to come out and let them show off their hard work / Pride&Joys.
I also posted a FB Link for those who prefer to have an event reminder: https://www.facebook.com/events/315271638665475/?context=create&previousaction=create&source=49&sid_create=1644929476
Date:
6th December 2014 (Saturday)
Time:
11am meet at the bus stop - 11:30 leave for the Cotter
Who:
Anyone and everyone. Any type of car, so invite your JDM/EU/AU/US m8s - friends and family too !
Where:
Meet at Hindmarsh Bus Stop >Cruise The Cotter >Lunch@ Pine Island.
Note: This will be an unofficial SAU Event so no lead car/ or insurance on the day.
Sounds great Jez, I'm free so put my name down.
I think a lead car is always a good idea. Maybe grab some Google map screenshots and mark out meeting points and driving route?
Byo bbq food/drinks
  • Like 1
I'm hoping for a more natural lead car where the slow guys can stay in one group and the other guys can do the 'obvious' haha
Yes, BYO - Food and drinks there is a BBQ there.
edit: Also, bikes are welcome to come as well.
Edited by RosieR34
Well, technically you're right - SG Fleet have my car hahaha
haha
yessssssss
It's okay technically i don't have my car either. The time i have owned it, it's spent more time at the mechanics :wub:
  • Like 2
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
