Hello friends and fellow car enthusiasts,
I understand that we have not had any ACT cruises this year, which is quite sad given that ACT is the greatest state and have some pretty awesome cars and decent enough roads (kinda) So, hopefully we can sneak a quick cruise in before 2015 starts. We've got some new cars and mods with our fellow ACTers and it would be great to come out and let them show off their hard work / Pride&Joys.
I also posted a FB Link for those who prefer to have an event reminder: https://www.facebook.com/events/315271638665475/?context=create&previousaction=create&source=49&sid_create=1644929476
Date:
6th December 2014 (Saturday)
Time:
11am meet at the bus stop - 11:30 leave for the Cotter
Who:
Anyone and everyone. Any type of car, so invite your JDM/EU/AU/US m8s - friends and family too !
Where:
Meet at Hindmarsh Bus Stop >Cruise The Cotter >Lunch@ Pine Island.
Note: This will be an unofficial SAU Event so no lead car/ or insurance on the day.
Sounds great Jez, I'm free so put my name down.
I think a lead car is always a good idea. Maybe grab some Google map screenshots and mark out meeting points and driving route?
Byo bbq food/drinks
  • Like 1
I'm hoping for a more natural lead car where the slow guys can stay in one group and the other guys can do the 'obvious' haha
Yes, BYO - Food and drinks there is a BBQ there.
edit: Also, bikes are welcome to come as well.
Edited by RosieR34
Well, technically you're right - SG Fleet have my car hahaha
haha
yessssssss
It's okay technically i don't have my car either. The time i have owned it, it's spent more time at the mechanics :wub:
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
