Hi I recently have started my build on my rb25det and the block is at the machine shop. But I am now onto the cylinder head and that is were I am having problems, basically I am trying to find out if I should port the cylinder head. I want to make 450-500hp and I was wondering if I can do without porting. I was thinking about removing the humps in the exhaust ports but what about porting the bowls, should I leave it or make a better transition from valve seat to casting. Btw the machinist is going to use a 3 axis valve seat grinder. Also I found some engine manuals for the cylinder head but non of them for the rb25det has any info on valves and valve seat clearances just a basic cylinder head disassemble that does not include removing valves, so if any one has any tech sheets that would be great as the cylinder head is next to go to machine shop.
Thanks
Richard
https://www.sau.com.au/forums/topic/450907-rb25det-cylinder-head-porting/
You can most certainly do without porting for that power figure. I made that power, as have many others before you - stock head and on PULP. If you plan on using E85 then it's a piece of piss.
All comes down to how deep your pockets are mate, and what the overall budget is. You can certainly save money on that if you need to spend it elsewhere.
I'd just do a quick clean up around the throat/seat area if keen .
You can fit slightly oversized exhaust valves with a bit of machining on the existing valve seats . All RB25 and 26 twin cam heads are a tad down on exhaust valve size and if you re do the exhaust valve seats they can be done for the OS valves in one go . Ferrea and one of the other mobs do them but I don't have part numbers .
I did this and had no power loss . The current trends with turbo engines is to do everything possible to free up the exhaust side so the engine runs more efficiently when on boost .
There is a supposed valve head area ratio exhaust to inlet and I can't remember accurately the numbers but the RBs end up being a tad small in the calc .
Doing this is a bit like having a very mild exhaust cam upgrade but no valve train geometry changes .
Works for me , cheers A .
Hi guys thanks for all the info. Btw I forgot to mention that I do not have e85 were I live, we only have 92-93 octane fuel so I was thinking of maybe running water/meth injection. I was also planning on putting valve springs and retainers in as well and keep every thing else stock.
Thanks
The first cm into the exhaust and intake port is the most critical on the short side, remove a valve and run your finger in there, you will feel a sharpish ridge that needs to be smoothed.
Removing the exhaust lumps also helps.
Dont make the ports any bigger as it will reduce gas velocity. (unless its a all out drag engine)
A basic port cleanup can go a long way.
Sure you can make good power without all this, need more power, run more boost, then again wouldnt you prefer to make it with lower boost levels and a turbo coming on quicker and stronger ....
Thats the most critical area, its the first cm or 2 i spoke of near the valve.
On both intake and exhaust, concentrate on the short side, on the intake its all around near the valve seat that needs work to smoothen the transition to the vavle seat.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
