In April The Z Club of Qld is hosting the nationals at morgan park. It's a Friday to Sunday thing with events from show n shine through to a proper supersprint, timed standing start + 3 or 4 laps. Best session time wins.
Entry forms are not out yet but are close in told. I hear conflicting stories it's could be on the 2100 m E layout or on the full 3 km K layout. They both have a good mix of speed and handling.
More information here
http://www.zcarclubq.org.au/event/nissan-datsun-nationals-2015/
Anyone keen? Duncan?
Edited by Noddy
https://www.sau.com.au/forums/topic/451353-2015-datsunnissan-nationals/
haha how did you know I'd be tempted :)
Hope they run it on the full track, I really enjoyed it....that sweeper on the back straight was great fun
I really enjoyed Morgan Park and will give it a go again, but I won't be ready to go by April.....maybe next time
might bring my Datto out for this if the costs are reasonable. Last DatNats up here was a bit ott.
unless someone turns up and whinges till they change the format again...
  • 1 month later...
Z Car Club don't seem to be doing much promotion of the nationals. This is all the info I've seen - doesn't seem to be widely circulated, so spread the word to people who might be interested...
post-15659-0-02902100-1421363207_thumb.jpg post-15659-0-47913100-1421363212_thumb.jpg
Single car sprints as well as multi-car side-by-side supersprints, and regularity for the oldies. Both Track E and K are rippers. K is the full track used in 2010 ASSC with the fast sweepers. Track E is the old full track and has a great esses section where it departs from K. No idea when entries actually open but SEQ people who go to an info night coming up are apparently able to sign on early to the track events. Maybe Z clubs in other states are doing the same thing?
Edited by hrd-hr30
nup, me either. Z Car QLD FB page and website have SFA. I have a couple of mates in the Z Car Club and even they haven't heard anything.
Nissan Datsun Car Club QLD are now trying to get some info out there. They managed to get hold of those fliers and have been posting them on Datsun FB pages. They've organised an info night at Yatala Pies Sunday Feb 1 6pm with someone from the Z Car Club to come and tell everyone what's happening. That's an open invite on a bunch of Datsun FB pages. But its only any good for SEQ people. It's supposed to be a national event, and easter isn't all that far away...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
