Hi,
I have a problem with my +12 V battery supply that goes to my aircon and stereo on my R32. The stereo stopped working and going through the cables I found that I didn't get power from the battery, ie. not the ignition one, but pin E on the diagram below. Strangely, when I switched the iginition on I got some power but not 12V from that cable. As I couldn't find any other way to fix it, I wired up another permanent 12V connection and the stereo was sorted.
www.installdr.com/harnesses/nissan-wiring.pdf
But after I put everything back together and drove the car, I realised my aircon now has a memory problem, which means it goes back to default every time I restart the car. I assume the aircon was supplied by the same wire that feeds the stereo and keeps the memory alive.
Now my question: Is this something obvious that is broken which someone has come across before, or does anyone know which pin on the aircon supplies power from the battery so I can also rewire that? I've been looking but haven't come across a pin out diagram for the aicron.
Any help is much appreciated,
Cheers, Chris
Got a multimeter? See if there is a good circuit from a fuse (unswitched power) to the AC plug. If it was an r33 I could ive you more help but I only have a diagram for an r33
On the R33's the constant power feed is recieved from a joint connector and Fuse #7
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
