hey guys its up fro sale cos i just lost my licence for nine moths thers no other rewason i would ever want to sell
1992 r 32 black skyline
micro tech ltx 8 computer
big front mount intercooler
polished surge tank with 500hp fuel pump
full 3 inch exhaust with cannon muffler
5 puck brass button clutch
hks turbo timer
boost gauge
turbosmart boost controller
retrimmed red interior front and back seats
veilside gear knob,momo steering wheel
jic fully adjustible suspension
18 inch deep dished chrome wheels 225 40z low profile tyrees brand new
custom whozup number plates
kenwood head unit with 6 by 9 speakers
this car is very fun to drive and the number plates are a pretty big invitation for races with alot of ppl.
not in a great rush to sell it but chasing 20 k sum post pics up for me please give me ur email then ill send them to you
thanks 0401425223
https://www.sau.com.au/forums/topic/45146-phat-black-r-32-whozup-pics/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
