hey guys i know its not a skyline i was a member here back in the day with my gtst series 2 and 3 months ago i bought a black 2006 sti, worked my ass off, fell in love with it and now its gone, Stolen outside my house last week kingsgrove about 3am, just a heads up if anyone hears or sees anything. Cheers guys
https://www.sau.com.au/forums/topic/451787-stolen-black-2006-sti/
