Event:
Happy Laps - Lakeside Park
Description:
A chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Breakfast will be served with bacon, eggs, beans and toast.
Lakeside Park
Date:
Sunday 8th February
Time:
7:00 AM Arrival
7:30 AM Breakfast
8:00 AM On Track
Cost:
$35 for members and guests of members riding/driving the members car.
$50 for non members.
Please note that this is a per person cost, any passengers are required to pay as well.
If you wish to come along to watch and not have breakfast it is free.
Requirements:
1. Participants must meet minimum age requirements for being on track.
2. No overtaking in the first 2 laps.
3. The overtaking car is responsible for completing the overtaking move safely.
4. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
5. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
6. Cars should not be more than 2 abreast at any point on the track.
7. Be aware of cars around you, in front and behind (and beside when being overtaken).
8. Do not assume that the car in front of you knows you are there.
9. Please pay cash on the day, no EFTPOS is available.
Lakeside Specific Rules:
10. Participants must have completed at least ONE QR Happy Laps before participating in a Lakeside session. (If you have done other Lakeside events before you may be eligible. PM me to clarify)
11. No overtaking or cars side by side on the kink.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&HappyLaps
Attendees:
  1. Cadmoon +1
  2. McFly
  3. AndrewK34
  4. gts032
  5. NW007
  6. Jamie RX7
  7. Ants
  8. Pete
  9. Andrew's mate
https://www.sau.com.au/forums/topic/452066-happy-laps-lakeside-park-8-02-15/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
