hi guys,
have an aftermarket boost gauge fitted and its not working so I want to pull it out. I've followed the vac line off the gauge sender to under the manifold in front of the drivers side. Its currently plugged into a nipple which seems to be giving off a little pressure (no vac).
Not sure if this is like a breather or what should actually be plugged into it. I also have the standard gauge which is working fine.
Anyone know what the nipple on the left is, and whether I can just remove the vac line and leave it open?
Cheers,
John
https://www.sau.com.au/forums/topic/452990-name-that-nipple/
The one with the little blue line off it is the factory boost solenoid/wastegate feed which goes to the open pipe you can see in the back ground
Just plug it up, but where is the wastegate line coming from ?
In that case should it be plugged it into the open pipe? I'll have to check where the wastegate is getting its feed from. I've also found what seems like another two open pipes closer to the oil filter, in the middle under the intake manifold, have no idea what these are for either and what should be plugged into them (if anything).
Came looking for titties, left dissapoint.
Boost gauge is sourced off the plenum. If you can't find it, give up and pay someone to work on your car. :P
lol had to get people to look somehow. i know where the standard gauge source is/should be, but now got me stumped on how the boost controller etc has been set up.
Not on a 26 it's not, it comes off the end of the balance tube next to the fire wall
OP, no that open pipe goes to a T the to one of the two by the filter, from there it goes to the boost solenoid then back to the other one of the two which then goes around the back of the engine to the intake pipe off the rear turbo, the other side of the T goes around the back of the engine to the wastegate
So if it's not the boost controller source then just cap it
If the information is lacking, the answers won't be accurate. Nowhere did he say RB26 and the car listed is S15...
I think you should Efix it for him Mick, that way when it blows up from unlimited boost you can feel less responsible. ;)
Really, you must work on cars a lot cause even I could tell that was a 26 just from that pic
And I'm just giving him info, what he does with it is his issue
And from the info he did give that line only goes to the boost gauge so capping won't blow up his engine, unless he is wrong and it is still connected to his wastegate
Thanks for the help mate, glad some people on here are still interested in providing useful advice.
Cant actually change my profile for some reason, but yes it is a rb26
Edited by Jaeyon
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
