RB Light Weight Flywheels $375
  • Replies 66
4340 is perhaps the highest grade high tensile steel that most machine shops can machine!!! THe japanese ones that are below 5 kgs are a totally different kettle of fish they are billet cast then machined (very expensive)... Also all you guys wanting to go below 5 kg have you thought of the effect on MAIN bearingS when doing this and not haveing the crank balanced; as you would in a rebuild.... Word of warning!! Going to light would be detramentle...
free bump!!!they sound good pity i have a tripple plate!!
nice price on the flywheel.
The comment about going below 5kg on a balanced flywheel causing any kind of damage to bearings is rubbish however. You should retract the statement for fear of scare mongering for business, a tactic I'm sure you are not advocating.
I'd like to point out that 6kg odd is still alot lighter than factory stock and for those who don't have $500+ to spend on a lighter unit it offers a cheap but, very significant performance increase.
the flywheels are CNC machined but are they also balanced at a significant rpm?
Guest darrinspencer
If you can't get 10 people, are we still able to get them even if its a bit more?
Ok
We can buy 6 now for $375 each at the same price as before
The group buy will remain open to try and sell the other 4.
The company is getting 20 made at the moment and they will be ready in 2 weeks
I will PM all people who wanted one and arrange payment once they are ready to ship.
Sky30: It depends on who you listen to. From my understanding, after fitting the flywheel the following is true:
- Torque will decrease, thanks to less inertia , due to less mass on the moving flywheel.
- The engine will rev faster, thus generating exhaust gas more quickly, thus spooling up the turbo faster. (This is faster in time, not faster as in lower rpm point) Unknown exactly how faster it'll rev... depends on load and enviroment, etc.
Guest Robo's
Ive been Reading abit about these, apparently its like dropping the weight by about 100kg in first gear, so you could imagine the accelaration. It takes less effort to run. The motor will spin freer, but noticeably idle a little rougher if you go too light.
Theres a couple of good reads on the net on these. Do a search!!
They're a wee bit of a trade off... lose a bit of torque down low, but who the hell cares because you're into the meaty power/torque zones faster, so it's all good. :)
If you really care about torque (as we all really should), do a 3L conversion or put some cams in.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
