Australia's Fastest Timed Runway Sprint is back for 2015
Event : Snowy Mountains 1000
What : 1000m Sprint on a Runway
When : Saturday, 28nd November, 2015
Where : Snowy Mountains Airport, 1611 Kosciuszko Road, Cooma NSW
- 140 entries up for grabs
- 100m of hotmix at starting area.
- Runway is 2.2km long with 1050m sealed braking area.
- Over 13 motels, plus pub/hotel accommodation, camping/caravan parks and B&B's
- Approx 1hr south of Canberra
- Great viewing areas for spectators
- Entertainment for the children
- Trade Stands
- We will also be running our charity rides again, racing money for the Cancer Council of NSW
2014 times, and current national (and some international) records:
More entertainment to be confirmed !!!
If you are looking to enter this years event, you need to email us at [email protected] as an entry EOI so we can send out regulations a few weeks before entries in mid April.
Edited by SM1000
https://www.sau.com.au/forums/topic/453537-2015-snowy-mountains-1000/
We have sent confirmation emails out to all those that have emailed us
The next part of the entry process is that we will email the event Supplementary Regulation and Catergory Descriptions a few weeks before entry. The actual day and time of entry will be included in this email.
- We will have 140 entries available on our entry list.
- Entry priority will be initially given to previous entrants of the Snowy Mountains 1000. They must however enter within a 12hr period. After this, entries will be opened to all others that have emailed us.
We would also highly recommend that if you have any other friends, family, workmates etc that wish to enter, that you encourage them to email us within the next 6 weeks.
  • 3 weeks later...
  • 4 weeks later...
This years Sup Regs and Category Descriptions will be getting emailed out in the next 2-3 weeks, with entries opening online 2 weeks after that. Only those that have been emailed the regs will have their entries (if not already full) accepted. Email us at [email protected] if you are looking to enter this year
  • 1 month later...
Entries Closed on Wednesday night last week. Thank you for all your entries for this years event.
The entry list for this years Snowy Mountains 1000 can be seen in our entrants gallery:
  • 1 month later...
Below are all the entered Nissans. I would say there are a few that would not be Forum frequenters.
ANDREW NISSAN 180SX
TOM NISSAN 180SX
ANDREW NISSAN 300ZX
JUSTIN NISSAN 300ZX
RODNEY NISSAN 300ZX
KATRINA NISSAN GTR R32
MAX NISSAN GTR R32
NATHAN NISSAN GTR R32
STEVE/ANTHONY NISSAN GTR R32
WARRICK NISSAN GTR R34
BRIAN NISSAN GTR R35
CHRIS NISSAN GTR R35
KEIR NISSAN GTR R35
LANCE NISSAN GTR R35
NICOLE NISSAN GTR R35
KEIRMAN NISSAN PULSAR GTI-R
TYRIE NISSAN SILVIA
NICHOLAS NISSAN SKYLINE
RICK NISSAN SKYLINE
SHAUGHN NISSAN SKYLINE
ANDREW NISSAN SKYLINE GTS-T
LUKE NISSAN SKYLINE GTS-T
THOMAS NISSAN STAGEA AUTECH 260RS
Edited by SM1000
  • Like 2
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
