Ok guys and gals, time to put these up for sells.
Genuine SSR Type C-RS
Gun metallic in colour
19x9.5 +22 5x114.3
Set of 4 rims with NO rubber.
Practically brand new, still in boxes with dust covers.
Comes with stickers, valve stems and caps, hubcentric rings and original papers.
Genuine lightweight racing rims made in Japan.
These are now discontinued and can no longer be purchased from SSR.
Would have been roughly been around $4000 landed when ordered new.
So grab a chance to snap up a mint set of rims.
$2500 ono plus postage.
Located 10mins south of Wollongong NSW.
The picture of the rim mounted was a test fit on my R32 GTR, which sat rather well.
https://www.sau.com.au/forums/topic/453643-ssr-type-c-rs-19x95-22-5x1143/
I have purchased a quaife front diff, so may consider swaps for other items with cash adjustment either way. I am looking at upgrading my gearbox ;)
  • 1 month later...
  • 4 weeks later...
Price drop. $2300 including postage to anywhere in Australia.
Would like them gone as I could use the funds elsewhere.
Yes, they are made with SSR's semi solid forging process.
These are a light weight competition wheel.
They also come with hubcentric rings which fit perfectly on a 32 GTR.
The last photo is a test fit on my car.
dem brakes tho
good looking wheels, glws
Thanks GHO5T.
They are pretty crazy brakes.
Im looking at building another set to on sell which will be of similar spec if you know anyone who would be interested.
  • 3 months later...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
