Hey,
I just finally pulled out my spark plugs and it appears the plugs my car was running ar..
NGK R PFR5A 11
Now i know nothing about this plug.. and Ive been told by a number of people, the best Plug for my skyline is the..
NGK BCPR7ES
Anyone able to let me knwo the difference between these two?
Thank you.
https://www.sau.com.au/forums/topic/45371-pfr5a-11-or-bcpr7es/
The one you took out was a heat range colder than the "recommended" one from NGK. Depending on what is done to your car that should determine what heat range you need. Correct me If im wrong (which i probably am) but i think for every 75hp you add to your engine you need to go a heat range hotter.
Ok Ive got it norrowed down to these few..
PFR5A 11 - These were in my car, and the safest bet is to replace them with the same one.
PFR6A-11 - These were Reccomended by NGK's Website
BCPR7ES - These were reccomended by a number of people on the forum
BCPR6ES - Same as above.
For record, my Car is apparently stock as a rock as far as i'm aware.
I am having some very bad starting problems first thing in the morning .. it MAY be the spark plugs, but im not sure if it is.
Stock heat range is apparently '6' .. So i wonder why the previous owner was running heat range '5' in the car?
I haven't had any probs with Pfr5g-11 they are expensive plugs but once you re-gap to the rite size say .8 - .7 depends on how much boost your running they should be fine.
You will also find a few most skylines will run a hotter plug eg the Pfr5 as it fires quicker then a colder plug eg the Bcpr7es.
Ok well I ended up getting a set of..
BCRP6ES
The reason being the following..
PFR5A 11 - Platnium 1.1 Gap
PFR6A-11 - Platnuim 1.1 Gap .. (yeha I know i cant spell that word)
BCPR7ES - Copper possible .9 gap
So I decidecd i wanted copper of platnuim, ..
and it just came down to choosing the correct heat range ..
considering i was running a heat of 5 .. i decided 7 would be cold, 6 is stock..
so ta-da!
im almost done im just not sue where one of these wires goes :D
Cool
make sure all the wires go back correctly, if its the same one I almost forgot to put back on, its the earth wire for the coils, it goes under the last bigish size bolt for the coils
let everyone know how it goes
Well I took it down the street and almost had to get it pushed home..
I forgot to tie up all the hoses so i blew a hose. or 4 :)
anywya with that fixed everything seemed fine.. except for that box that sits up the back over the cover.. i accident put the wrong bolts in the coil pack
so i dont have this bolted down .. also there is a little thing hanging off that box, which has an earth and i have NO IDEA of where to atatch the box and this earth too
:S
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
